BT Smart Hub
johna1414
BT Smart Hub
Hi
When I moved from BT to Plusnet in 2021 the router I was sent by Plusnet (Plusnet Hub 1) did not give me a particularly good speed so I programmed my BT Smart Hub 1 to use with Plusnet and it improved things.  I am now on a new Plusnet contract and use the Plusnet Hub2 they send me.  The service has deteriorated again so my question is can I programme by old BT Smart Hub 1 to use again on my new contract and is it likely to improve things.  If not any other suggestions.
16 REPLIES 16
Fixes: 388
Re: BT Smart Hub
@johna1414 Your BT Hub should work on your new contract without any 'reprogramming', so long as you haven't changed product.
Fixes: 480
Re: BT Smart Hub
@johna1414
In what way has it deteriorated?
Fixes: 480
Re: BT Smart Hub
Moderator's note:
Thread moved from Broadband to My Router
johna1414
Re: BT Smart Hub
Hi, just slower than it was when i was using my BT SmartHub 1 when i had my old Plusnet contract.  When i signed up for my new Plusnet contract they sent me a new router which i am using at the moment but it is slower.
Fixes: 388
Re: BT Smart Hub
In what way is it slower?
johna1414
Re: BT Smart Hub
Just slower at loading pages while browsing really
Fixes: 388
Re: BT Smart Hub
To be honest, that doesn't sound much like a router issue, but as I said above, there is no 're-configuring' needed on the BT Hub.
Try substituting it for the PN Hub2 and see how you get on.
Re: BT Smart Hub
@johna1414
which product are you now on,  it may not be suitable for Full Fibre.
Clearly you would need to change the broadband username password pair for you current contract.
johna1414
Re: BT Smart Hub
definitely slower since the day i started on my new plustnet fibre product contract.  it came for a new PN Hub2 (the one with a circle on the front).
johna1414
Re: BT Smart Hub
we live in the country and do not have full fibre all the way to the house.  last bit is still BT copper
Fixes: 388
Re: BT Smart Hub
I know you say pages 'seem to load slower', but that is subjective. What speeds were you advised to expect, in your new contract?
johna1414
Re: BT Smart Hub
Hi, yes i agree it is subjective but i have been with PN since since 2021 so don't really expect my new contract which started a couple of months ago to be worse.   i guess i have probably answered my own question here.  in 2021 when i moved to PN the router they sent me did not give me the speed i had with my BT router so i reprogrammed the BT Smart Hub 1 to work with PN.  It got better so i probably just need to go back to using the BT router again.
Fixes: 585
Re: BT Smart Hub
@johna1414
Are we talking wireless speeds here ?
I ask because the Plusnet Hub2 is basically the same as the BT Smart Hub 2, which in theory should be better than the BT Smart Hub 1 (and Plusnet Hub 1).
If the problem is just wireless speeds, then it could be as simple as changing the wireless channel. By default , routers are usually set for automatic channel assignment, meaning they scan for adjacent wifi networks and try to pick a channel with least interference. However they often don't do it very well!.
johna1414
Re: BT Smart Hub
thanks, I could try that if i knew how.  i will see if i can get some instructions online.
