BT Smart Hub 6 rebooting everyday at 12am
Trekkie
Re: BT Smart Hub 6 rebooting everyday at 12am
😀 No reboot at around midnight, just for info log reports an hour later ppp1:TR69 ConnectionRequest: processing request from ACS and ppp1:Request for a new authenticated connection, but no reboot. Will keep an eye on it for the rest of the week. Thank you Bob.
bobpullen
Fixes: 330
@androidtanmay, something I had corrected for the two routers in question. I expect others affected by the issue will be sorted before too long.
androidtanmay
@bobpullen
Thank for replying Bob. Can I request you to do it for me as well? Had to switch back to PN Hub1 from HH6A due to this reboot issue which affected my connect stability and speed and ultimately my work. The PN Hub one gives a issue with 5Ghz throughput even though you have updated me to the .280 build.
bobpullen
Fixes: 330
@androidtanmay it's not directly within my gift, but if you private message me the serial number of the HH6A then I'll see what strings I can pull. If not, it will be a case of waiting for a wider fix (which I don't expect will be too far round the corner anyway).
The .280 Hub One build is affected by both the throughput and 5GHz connectivity issue. I have a build that will help with the latter, but not the former (yet).
androidtanmay
@bobpullen
Thanks Bob. have sent you a PM with the serial number. It just gives a better wifi range and coverage and offers better experience during skype calls etc. hence a bit keen on this. In the mean time happy to test the other build on PN H1 which may address the throughput issue.
Trekkie
@bobpullen, Hi Bob, This error occurred today and we lost connection,
Hope it's just a one off, but I work from home and if this was to happen more often the Hub one will have to come back into service again. Can you verify what it means?
11:21:19, 13 Aug.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
11:21:18, 13 Aug.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
11:21:18, 13 Aug.
ppp1:TR69 receiving InformResponse message
11:21:18, 13 Aug.
ppp1:TR69 event found : 4 VALUE CHANGE
11:21:17, 13 Aug.
ppp1:TR69 sending Inform message
11:21:16, 13 Aug.
11:21:15, 13 Aug.
11:21:15, 13 Aug.
ppp1:TR69 creating new session with ACS
11:21:09, 13 Aug.
:WAN: SENSING AUTO VDSL
11:21:09, 13 Aug.
ppp1:New DYN ROUTE is added [212.159.6.9/32 gw 195.166.130.255]
11:21:09, 13 Aug.
ppp1:New DYN ROUTE is added [212.159.6.10/32 gw 195.166.130.255]
11:21:09, 13 Aug.
ppp1:PPP: PPP INFO 212.159.6.10,212.159.6.9
11:21:09, 13 Aug.
ppp:PPP: IPCP_NAK
11:21:09, 13 Aug.
ppp:PPP: CHAP_SUCCESS
11:21:09, 13 Aug.
ppp:PPP: CHAP_RESPONSE
11:21:09, 13 Aug.
ppp:PPP: LCP_GOOD_ACK
11:21:09, 13 Aug.
ppp:PPP: LCP_REQUEST
11:21:09, 13 Aug.
11:21:09, 13 Aug.
11:21:09, 13 Aug.
11:21:09, 13 Aug.
:PPPoE error: timeout
11:20:59, 13 Aug.
:HTTP UserBasic login from 192.168.1.66 successfully
11:20:53, 13 Aug.
11:20:44, 13 Aug.
11:20:40, 13 Aug.
11:20:36, 13 Aug.
ptm0.101:VLAN VLAN_DATA connected
11:20:36, 13 Aug.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
11:20:36, 13 Aug.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
11:20:35, 13 Aug.
dsl:VDSL link Up: Down Rate=91252Kbps, Up Rate=9997Kbps, SNR Margin Down=0.00dB, SNR Margin Up=5.00dB
11:20:19, 13 Aug.
11:20:19, 13 Aug.
11:20:15, 13 Aug.
11:20:14, 13 Aug.
11:20:13, 13 Aug.
:VLAN VLAN_DATA disconnected
11:20:12, 13 Aug.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
11:20:11, 13 Aug.
ppp1:The DYN ROUTE [212.159.6.9/32 gw 195.166.130.248] is deleted
11:20:11, 13 Aug.
ppp1:The DYN ROUTE [212.159.6.10/32 gw 195.166.130.248] is deleted
11:20:10, 13 Aug.
dsl:VDSL Link Down: duration was 138896 seconds
bobpullen
Fixes: 330
@Trekkie the clue there is:-
Your router lost connection with the local cabinet.
The only reason you see reference to TR069 is because an inform event will take place after the connection comes back up.
In short: completely unrelated to what you were seeing before.
Rosliv
Hi bob, having the exact same issue described, home hub is rebooting at 12:00 everyday,
The serial Number is: +084317 +NQ62313246
bobpullen
Fixes: 330
Midday or Midnight?
Are you able to provide an excerpt from the router log?
Trekkie
Hi Bob  @bobpullen  Since we last spoke the router has been stable and then I upgraded to Fibre Extra, and now every night not just at midnight but around 6am, and today at 10am, I lose connection. Can you help identify the cause? I attach the latest logs.
Fixes: 476
@Trekkie
If you read this post you will see the reason.  https://community.plus.net/t5/My-Router/BT-Smart-Hub-6-rebooting-everyday-at-12am/m-p/1759961#M20902
For some reason your line is dropping, it's not this particular firmware issue. There are all sorts of possible causes. It would be helpful if a Plusnet staffer could post a radius chart to see the pattern.
Edit
For the record this last drop was after about 2hours 32 seconds. How long is it since you upgraded? It's possible that the DLM will automatically reduce your SNR to improve this soon.
Trekkie
Thanks @Baldrick1 My upgrade was on 28th August, so do you think it will sort itself out?
Fixes: 1,495
It's probably better to start a new thread in the fibre board if you're suffering line drops.
Fixes: 476
@Trekkie
It's still early days and only time will tell. When you upgraded the DLM was probably reset to the default 6dB. You can see where this is currently set if you look at the Noise Margin on the Smarthub advanced/technical log page. There's no point reporting it at the moment as you will be simply told to wait for it to 'tune' DLM to the line.
If it doesn't change over say the next week then as @dvorak suggests, I would raise a new topic on the Fibre board so that it gets more visability.
damianmcr
@bobpullen
Sorry to drag up an old thread but I am having this exact problem on this firmware.
I installed my HH5 088315 2 days ago.
Can you help?
