BT Home Hub 6 (Smart Hub) on PlusNet
incrediblechunk
Re: BT Home Hub 6 (Smart Hub) on PlusNet
 Hi, I successfully sorted it today. I did the internal factory reset (though on doing so remember I had done that before). The other thing I did was change my account password prior to trying to connect. Personally I think it was the password change that did it. Thanks for everyone's help, especially LoM for all the time he's taken on this thread.
Rich2
Hi, would the same principle with the Hub 6 work on VF?
LifeonMars
Seasoned Pro
Fixes: 12
As far as I know The Smart Hub 6 will only work with BT and Plusnet.
Mustrum
Fixes: 81
There is no reason why it would not work with other ISP's if you know the username and password to use, or the structure of those fit into the space available - it won't work on EE for example as their usernames are too long.
Rich2
Thanks for replying, can you explain what the "structure is" please and do I just ask Voda for the user name and password?
Mustrum
Fixes: 81
You can try asking Vodafone for your username and password, I have seen some reports that they like to use their router - as most ISP's do, as it makes it easier to support if something goes wrong. The structure is just the combination of letters, numbers and symbols - not sure exactly what the Hub supports, I just know EE's combination does not work.
That said, a search on the VF community site should give you more useful information.
Rich2
Hi, thanks for your help
Alex
Fixes: 13
As LifeOnMars said, I thought the routers were locked down to just BT and PlusNet?
Don't ask me why they do this - I don't agree with it.
There is a post on here from someone who hacked this unnecessary restriction, but be prepared to take the thing apart and get your soldering iron out Roll_eyes
LifeonMars
Seasoned Pro
Fixes: 12
Since
SG4B1000B316
27-Jul-2017
The BT Smart hub (6)  appears to no longer reboot its self every 14days.
Fixes: 480
I have been using a Smart Hub for about 10 days now. Every day it appears to check in with presumably BT. See attached: is this normal?
LifeonMars
Seasoned Pro
Fixes: 12
Looking at the BT Smart Hub 6 forum,  I would say Yes.
https://community.bt.com/t5/Connected-Devices-Other/TR069-Connection-Request-Failed/td-p/1675314
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules
malkpm
I hope this helps....
Have just put a hub 6 (brand new) in and the speed has increased.
I am on FTTC. Previous best was 7.3mb down. Now I am getting 9.25. This is as reported by the modems. Online speed testers show a great increase as well.
I am waiting for the BT wifi status to go off.
No more buffering on Netflix. Yippeee!
LifeonMars
Seasoned Pro
Fixes: 12
The BT Wifi status would show not active once you have rebooted
onthequiet
I've just defected from BT.
I was getting a good 22-23mb with the Home Hub 6 and BT.
Then I changed to Plusnet. Initially I thought "great" as managed to get a low 24mb with perfect conditions. I quickly noticed however that the wifi was nowhere near as good with the Plusnet One and so reverted to my Smart Hub. I was also getting some dropped connections.
This is where it got strange...  Quite simply, I have
  • reset the Smart Hub to factory settings
  • turned off the smart setup
  • entered my plusnet broadband username and pw
the most I can now get with the Smart Hub over Plusnet is 17mb.  Whats that about?
Is there some other optimisation technique for the Smart Hub over Plusnet or why am I losing some vital mb.
Also, the speed seems more 'inconsistent' (both Smart Hub and Plusnet One) than BT. Sometimes I'm getting 17mb (Smart) and then other times I'm getting 7 or 8 mb.
Any advice? Thanks
LifeonMars
Seasoned Pro
Fixes: 12
Perhaps a line fault or something not quite right at your exchange when the switch was made.
Some one at plusnet should be able to check your line.
