BT Home Hub 6 (Smart Hub) on PlusNet
LifeonMars
Seasoned Pro
Fixes: 12
Re: BT Home Hub 6 (Smart Hub) on PlusNet
I can only suggest doing a hard reset, Make sure that you hold the reset button for a considerable amount of time to reset it.
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-hub-to-its-factory-setti...
Gel
Champion
Fixes: 29
DaveyH
Champion
Fixes: 12
No DNS is hard coded like the HubOne
petelane1951
Thanks to everyone on this topic. Just bought HH6 in place of Hub One. Managed to set it up with only minor problems and now working well.
LifeonMars
Seasoned Pro
Fixes: 12
You will find that every 14days it will reboot itself and also will receive the latest updates.
silverblack7777
All setup on HH6 i just reset the hub then went to advanced settings/broadband and entered my plusnet user/pass then connected.
incrediblechunk
Firstly thanks for all the posts in this topic, very useful. Unfortunately, it isn't working for me. I have two Home Hub 6's and have tried it with both. When I click connect at the end of the process I get a small 'Error' window popping up on my screen every time. I've double checked I'm using the password I log in to my Plusnet Member area with and also using the user name with @plusdsl.net at the end. I'm wondering whether attempting to change my username or password or both might help. Any suggestions people?
LifeonMars
Seasoned Pro
Fixes: 12
All I can suggest is doing a Hard reset, Making sure you keep the reset button in for a very long time.
incrediblechunk
Thanks LoM. Are we talking until the lights go out and it reboots or persisting for a few minutes? I got onto customer services yesterday and (after telling me the HH6 wasn't compatible) they confirmed my username and password are correct but I might try changing them after the next reboot.
LifeonMars
Seasoned Pro
Fixes: 12
Sorry to hear of your problem, all I can suggest is read this again
see     Message 41 of 69
https://community.plus.net/t5/forums/v3_1/forumtopicpage/board-id/Broadband/page/3/thread-id/306720
Good Luck
incrediblechunk
Cheers LoM. I reckon I've memorised that post word for word I've read it that many times. Would you mind telling me how long you would estimate  the reset button hold should be for?
LifeonMars
Seasoned Pro
Fixes: 12
It is fiddly, Try 2 mins
Perhaps the hub is faulty.
Good Luck
LifeonMars
Seasoned Pro
Fixes: 12
Have you also tried a Factory reset from within the Hub under
http://192.168.1.254
advanced settings.
and unchecked smart setup .
incrediblechunk
No, but I'll give that a go tonight. Many thanks LoM
silverblack7777
That's what i did factory reset from settings then entered my user/pass and connected straight away.
