BT Business Smart Hub 6 Type A anf FTTP
Fixes: 115
Re: BT Business Smart Hub 6 Type A anf FTTP
@Empire
Assuming you're with PlusNet the lowest speed you can order is 78/10. As there are no distance limitations with Full Fibre you tend to get close to the advertised speed.
If connecting by ethernet then it'll work fine. WiFi is a different matter. However it should continue to work until such times as it leaves this world.
FYI - OR ONT's currently look like this. https://support.aa.net.uk/Openreach_FTTP_ONT
Fixes: 380
@bmc I don't know the capabilities, wireless-wise of the BT Hub6, but wherever I am, in my admittedly small property, I get almost identical speeds.
This is on a 100/20 connection, using a Fritz!Box 7530.
Fixes: 579
I believe the BT Business Smart Hub 6 is the same hardware as the Plusnet Hub 2. The Hub 2 is capable of handling a 900/115Mb FTTP connection.  Its wifi is only Wifi 5 capable and so will be limited to around 400Mb but you would be able to achieve the full 900Mb via ethernet (assuming you were willing to pay for a Full fibre 900 product).
