Attempting to set up a AC2800 VDSL Modem Router
acomelyltd
Finally got my fibre to the cabinet installed yesterday and then found Openreach no longer supply a modem as part of the install. So no problem, wanted to upgrade my router anyway, so went out and bought a TP-Link AC2800 modem router. Have been through the setup process, both automatically and manually several times, but it refuses to connect to the internet. On checking the logs I am getting "CHAP authentication failed" despite using the correct [email protected] and password used to log into members centre. Never had any issues establishing a link at my previous address with the credentials so I know they are correct. Have tried phoning the help line, but am still listening to some not very appropriate music after some twenty minutes, so thought I would post on here in case there is a simple solution, as I am becoming increasingly disgruntled at both Plusnet and Openreach due to having notified them of a change of address two months ago, but Openreach didn't action until the situation was escalated.
Andy
Tags (4)
2 REPLIES 2
Fixes: 116
Re: Attempting to set up a AC2800 VDSL Modem Router
@acomelyltd
I'm not a techie but if you previously used an OR Modem then I believe it still works with FTTC so you could go back to your old setup.
Also, has PN not supplied a Hub2 which you could use short term while you figure out the AC2800
Fixes: 477
@acomelyltd  Welcome to the forum.
Have you got the Point to Point Protocol set to PPPoE? Some hubs default to PPPoA and the VLAN set to 101, see. https://www.plus.net/help/broadband/broadband-connection-settings/
