Asus GT-BE98 Router
pete66
Asus GT-BE98 Router
Hello i have an Asus-BE98 router which worked really well on EE. Can i use it on Plusnet to replace their router please. If so is the setup the same as EE. Thank You
4 REPLIES 4
Fixes: 585
Re: Asus GT-BE98 Router
@pete66
You will need to change the PPPoE credentials to those for your Plusnet account. Username is <youraccountname>@plusdsl.net and the password is your account password
markhawkin
Champion
Fixes: 22
The only thing to know is that the settings for Plusnet are specific to your account (as explained above).
I think EE has "generic" account and password.
Just get your account and password in and it should "just work".
Nothing else to change!
One of the benefits of having your own router.
pete66
@MisterW Thank you thats what i needed to know..
pete66
@markhawkin Yes EE just use the Generic BT login etc. Thank you thats relly helpful.
