ALL Internet goes when we use any wired connection
harry13
we have been losing internet from time to time from 10 minutes to hours at a time, Plus net have found no fault their end. on my 3rd Hub 2 and this one didn't work at all for 2 days.
We 1st thought it was something to do with my Fired stick which was being used via a LAN cable, but after less than an hour it happened again with the PC, all connection, both wired and wifi go when any device is being used via a wired connection, being one particular connection or cable I could accept it being a fault in my home network, but not allowing any wired connection seems to me a Router problem? Right now it's only working with everything device being used on wifi, something I don't want,
11 REPLIES 11
PhilipHeyes
Seasoned Champion
Fixes: 21
Re: ALL Internet goes when we use any wired connection
By chance do one or more of the devices have a static IP set on their network adaptors
that are clashing with the Hub's IP or the Hub's DHCP range ?
Does the Fire Stick have any "custom Sky access software" or similar on it that could cause an network conflict ?
Do you have any other network devices or switches that could be configured in a network loop ?
Anything that runs a conflicting DHCP ?
markhawkin
Champion
Fixes: 22
The "dodgy fire stick" is a good call.
Disconnect all wired devices, then connect each one in turn in order of least "suspiciousness".
Consider carefully range extenders, and network connection over mains devices.
It doesn't sound like a physical router problem.
I once had a similar problem that turned out to be a problem with a device that had both a network connection and a cabled connection. It wasn't a printer but some printers can do this.
Anything change when the problem started?
ExForce9
Seasoned Pro
Fixes: 10
@harry13
Using a wired PC, when there isn't much other activity on your network, run this test - waveform.com/tools/bufferbloat
When the test ends, scroll down to where it says "Share Your Results:", press the [Copy] button on the right hand side,
then come back here and paste the result URL in to your reply.
While the test is running, keep an eye on the router's blue light, and check whether it goes orange ?
harry13
The Router does give us the Orange light though,
harry13
https://www.waveform.com/tools/bufferbloat?test-id=8ecc69f2-d970-43ca-bffa-206f4e1c7d13
Saying it's alright, this is only the PC wired and everything else still wifi, been like this last 10 mins and as yet no issue, router still showing blue light
PhilipHeyes
Seasoned Champion
Fixes: 21
You have answered no questions, it this a walk up the garden path ?
harry13
I wouldn't know, everything is as it was when 1st turned on or installed,
Fixes: 583
@harry13 is your connection a Full fibre or via the phone line ?
If its the latter , then make sure you haven't got anything connected to the red WAN port on the Hub 2
ExForce9
Seasoned Pro
Fixes: 10
@MisterW   the speed test in Message #6 shows that it's 500/70Mbps full fibre, and the throughput looks good.
markhawkin
Champion
Fixes: 22
@harry13
The next time it all plays up, unplug the Firestick Ethernet conection.
The more I think about this, the more I suspect that the Firestick is taking connections by both WiFi and the cabled connection and that's what is breaking your connection.
@harry13
Next time you see this issue can you share a copy of the Hub two event log?
Best performed using a PC or Laptop
Navigate >Home >Advanced settings >Technical log >Event log. Select Export, this download a CSV file to the download folder
Use the paper clip below the reply window to attach the file.
You mention the hubs light being Orange, is this for prolonged periods or flashing?
