wi fi connection
markbivvy
Re: wi fi connection
Thanks all,now sorted.
@markbivvy
What was the issue?
markbivvy
Hi D.
 looks like it was a admin issue just needed the account sorting at there end,or just my impatiens.
thanks
markbivvy
yes,both boxs are side by side connected to each other.
What do you mean with the above.
 router and the little white box with the green led,s.
I must admit I'm confused a bit.
Maybe a confusion of terms
Did you mean wifi connection being your internet connection or devices connecting to the Hub Two using wifi?
markbivvy
could not get the mobile phones to connect,was getting wrong password all the time,and the scan option was duff.
markbivvy
wifi was working sound as the pc connected via the pairing button on the router.could not work out why the phones would not connect.
 turns out it was waiting for plus net admin to do there bit.
