getting internet connected
jemilyjones
Hi, I have just moved house and my phone line is connected. My internet is due to be connected . Does anyone know whether my router settings will stay the same, or whether I will need to do something different to the router?
2 REPLIES 2
Fixes: 387
Re: getting internet connected
@jemilyjones Have you done this as a 'house move'? If you are still going to be using the same equipment, then you should just be able to 'plug and play'. Are you waiting for the actual fibre connection being made, or what?
jemilyjones
Thanks - it was indeed 'plug and play' having not moved house in a long time, I wasn't sure, so thank you for your help.
