activation date
dyoung1981
activation date
my broadband goes live tomorrow but i have solid blue light on my router but wireless and internet not working can someone take a look see if may have gone on early or in process im using the setup as username and its blue
12 REPLIES 12
dyoung1981
Re: activation date
if someone can take a look at this when they can would be great thank you👍🏻
Fixes: 1,485
Re: activation date
Moderators Note
This topic has been moved from Fibre to My Orders
Fixes: 1,485
Re: activation date
You could try replacing the 'setup' username with your own account name / password combination and see if that works
dyoung1981
Re: activation date
can i do password reset?
Fixes: 1,485
Re: activation date
shouldn't need to do a password reset, the details are the same that you use to log in to the PN member centre.
dyoung1981
Re: activation date
ok thank you ik try that now and let you know
Fixes: 1,485
Re: activation date
the username for the router is <username>@plusdsl.net
dyoung1981
Re: activation date
the password isnt working just red light now
Fixes: 1,485
Re: activation date
order probably hasn't completed then, need a staff member to confirm that.
dyoung1981
Re: activation date
ok thank you
dyoung1981
Re: activation date
hi ive had an email that my broadband is now live but when i use password its not working can you advise what to do next
Fixes: 1,485
Re: activation date
easiest thing might be to stick a pin in the back of the router for 30 seconds to do a factory reset and let it detect the settings.
