Yet Another FTTP Installation Query
pvmb
Champion
Fixes: 16
Re: Yet Another FTTP Installation Query
@pvmb wrote:
...OK., I will do that. Thanks.
Reply: "An engineer may already be allocated to attempt the external work. If not, we'll aim to completete everything on your planned appointment date"
The race between my "ACCESS" text and the installers was won by the installers! They've been and gone.
I now have a grey Openreach CSP box mounted on an external wall. It's slimmer than I expected.
They called when I was in and so I got to speak with them, they wanted to know where my router was (on the extension socket) and I explained where I wanted it to end up being (next to the BT landline master socket) . They have left it as a problem for the ONT installer to route the incoming cable through two walls via an external cupboard.
So no internal CSP but the ONT should end up on a wall adjacent to the current BT landline socket. A nice compromise as that means I can still get my hands on the eventually unused Openreach NTE and see if I can use the landline extension cable to perhaps pull an Ethernet cable through to the router/PC's current location. Meanwhile I will simply use the already tested 5GHz Wi-Fi link to get from the router's eventual new location to the PC.
mystreet1
Seasoned Pro
Fixes: 7
Depending upon thd speed that you need, you may be able to use the telephone extension cable as an ethernet cable. Others on here have done it. I will let them explain how to.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
