Yet Another FTTP Installation Query
pvmb
Champion
Fixes: 17
The situation is I have now renewed my Plusnet contract for a new FTTP connection.
Openreach have sent me two text messages. The first speaks of "access to the outside of your property to complete pre-work and attach a small box." (I know this would be the CSP box) "Once complete we'll confirm your appointment date."
This seems to me to imply two Openreach visits. One to attach the CSP outside my property - where I don't need to be present - followed by a second, internal visit to set up the ONT.
Can anyone confirm this interpretation?
Now I was rather hoping that the CSP could possibly be mounted inside the property alongside the ONT. However I realise this may not be possible.
There is an option to reply "ACCESS" to the initial text message if home owner needs to be present for CSP install. Possibly I could take advantage of this?
16 REPLIES 16
Fixes: 388
Re: Yet Another FTTP Installation Query
@pvmb That sounds strange to me - the job is usually completed in one visit of approximately two hours. I don’t see the need for two visits.
Fixes: 118
@pvmb
What does the Checekr say?
To the right of WBC FTTP does it say One Stage or Two Stage?
Below the window, what does the narrative say about the FTTP install.
You might still be able to get the CSP inside - speak to whoever turns up.
pvmb
Champion
Fixes: 17
...That's what I had hitherto expected. However the text definitely says "Once complete, we'll confirm your appointment date." - Where "complete" appears to be the installation of the CSP box.
Text continues: "Reply ACCESS if someone needs to be present (e.g. locked gates) or MORE for extra info"
RealAleMadrid
Fixes: 68
@jab1  It's very common for FTTP installs to specify 2 visits particularly if fed underground and OR have no idea if the ducting is clear. In fact in my case the checker said my line was partially direct in ground which was wrong, older houses on the estate do have DIG, there is a lot of OR work going on to put ducts in. My first engineer visit found my duct was blocked, and just marked it and left. That was on the 9th of April, thanks to Openreach being totally incompetent at arranging anything my FTTP was eventually activated on the 4th of July.😫
pvmb
Champion
Fixes: 17
@bmc wrote:
@pvmb
"FTTP Install Process - KCI2 Assure"
Here is a likely explanation of this:
Re: KCI2 Assure
https://community.bt.com/t5/BT-Fibre-broadband/KCI2-Assure/td-p/2419277
Possibly this:
"an issue with your address ( although the same issue may affect many others ) was identified that requires the installation to be done in two stages"
"An example could be, someone’s existing copper pair service is underground but not ducted..."
@bmc wrote:
@pvmb
"Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Pre built to curtilage hard"
Sounds like I may need to reply "ACCESS"! I'd rather I was at home for the CSP install, so I can discuss it with the installer.
Fixes: 388
@pvmb If it was me, I’d be asking for more info.KCI2 means they need to do a survey first.
Fixes: 118
@pvmb
The Checker results show that OR don't know what state the access is to your property. If I remember correctly HARD means they may have to trench accross a "hard" surface.
I agree with @jab1  - text MORE to find out what's happening.
I would be there on the day.
Fixes: 480
My installation was KCI2 pre built to curtilage soft.
The first team of subcontractors came and installed a jolly box in the pavement and a duct across my soft dig lawn They also installed a draw rope
Contractors from a different company did the fibre installation.
I assume that your duct has to cross paving/tarmac, the fitting of which probably requires different skills/teams and tools to fibre installers.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Order
pvmb
Champion
Fixes: 17
I'm not really bothered if it takes two visits to install FTTP. I am bothered about whether I will be in and consulted on both occasions. The Openreach text appear to me to cast some doubt on this matter.
Fixes: 480
I would text access. In my case I happened to be home when an Openreach guy turned up to spray mark the route for the dig team to lay the duct across the lawn. There was no notice that he was coming.
pvmb
Champion
Fixes: 17
...OK., I will do that. Thanks.
Reply: "An engineer may already be allocated to attempt the external work. If not, we'll aim to completete everything on your planned appointment date"
pvmb
Champion
Fixes: 17
In my case, the situation is a bit unusual as the distance from my property and the existing BT ground chamber - for access to landline and now fibre - is measurable in inches!
The physical distance from this BT ground chamber and my existing BT/Openreach landline master socket is all of six feet. Unfortunately, as the property pre-dates 1990 and the existing landline cable is armoured, there is likely no duct feed to the existing socket.
I have in mind my own 'ideal' solution: with the CSP and ONT being installed adjacent to the existing master socket. Which I would also like preserved so I can perhaps make use of it later on. Also, there are no power sockets available at this location.
So it's all very 'theoretical' at the moment. 😊
Fixes: 480
It might only be 6 feet but it is across a hard surface. This means you need a team with cutters and heavy digging tools to install the duct plus probably another team to make good the damaged surfaces. KCI 2 means Keep Customer Informed, the 2 means that it is a multi visit installation process.
It is not unusual for the fibre duct to take a short route to the property then the fibre be 'clipped' to the external property wall to a suitable entry point.
