Txt message
- My Order
- Txt message
Txt message
08-05-2018 9:01 PM
Received a txt saying
Your broadband order has successfully completed. If you want more information, go to http://help.plus.net. Connection problem? Visit http://faults.plus.net
After getting the txt I set up my new router but I still have a red light on my router? Will I get another txt when it goes live? Or should it working straight away?
Thanks in advance
Thanks in advance
Message 1 of 3
(237 Views)
2 REPLIES 2
Re: Txt message
08-05-2018 9:46 PM
Message 2 of 3
(225 Views)
Re: Txt message
09-05-2018 9:36 AM
Hi @Simmie88
Apologies for the issues you have had with your broadband. While the order had completed on our supplier system it looks like your account hadn't fully activated to reflect the completed order. I have updated the details for you now so you should be able to connect to the internet.
Let us know if you experience any problems.
Message 3 of 3
(206 Views)
