Time frame for new order
Fergin
Hi
Can anyone advise what time frame a switch to plusnet should take, I’m transferring from sky to plus net and it’s been a couple of weeks, not desperate as sky internet still working, just wondering
regards
Fergin
10 REPLIES 10
MatthewWheeler
Fixes: 487
Re: Time frame for new order
Hi @Fergin
I'm really sorry to hear you've had no updates on your order.
It looks like the orders didn't get placed due to a system issue so I've resubmitted those for you now.
You should get further updates in the next 24/48 hours
 Matthew Wheeler
Fergin
Thanks,
not a good start, seems quite a regular thing looking through forum
Lajacobs
I have been waiting since 13th May, have been told there had been a mistake in my order so they reordered on 3rd June and have been given a date of 13th June, I am not holding my breath! If it doesn’t arrive on that date I will cancel and get someone else, I think a month is long enough!.
Fergin
Seems all to common,
Fergin
ClaudiaG23
Fixes: 25
I understand that @Fergin. I've just checked and the orders are now been committed for the 23rd June.
@Lajacobs I can see your orders have now been placed and the Suppliers have confirmed the activation date of the 13th June. I've double-checked, and there should be no reason for a delay with this.
 Claudia Garner
Fergin
Why on my status page does it say strCustActivationDate instead of a date, this is what it originally stated before you re ordered can you confirm this is going through
fergin
MatthewWheeler
Fixes: 487
Thanks for getting back to us @Fergin
I'm not sure why it's saying that but as Claudia advised above everything is still due to complete on the 23rd
 Matthew Wheeler
corringham
Seasoned Champion
Fixes: 17
This is the name of the variable that holds the activation date. The code should print the value of that variable and not its name. It is very sloppy programming, it should have been picked up in testing, it would take minutes to fix - yet it has been like that for several years.
The time spent answering questions like this will be far more than the time it would take to fix it - but Plusnet don't care.
Fergin
I’m assuming the new router will arrive in time for this date as my order status still says preparing
fergin
MatthewWheeler
Fixes: 487
Evening @Fergin
Yes that's correct our systems automatically ordered the router a few days before your services are due to go live and it looks like this has happened this evening.
Once the router has been dispatched you'll receive an e-mail and text with a link to Royal Mail's tracking service so you can check the delivery of it.
 Matthew Wheeler
