Switching problem
- My Order
- Switching problem
Switching problem
yesterday
I’m looking to switch back to Plusnet after a long hiatus. I was hoping to order online to qualify for a £125 reward card through MoneySupermarket but there is an error and I need to call Plusnet to proceed.
The error is due to an address mismatch between the Royal Mail PAF and the Openreach database. Openreach have advised to ask my current supplier to raise an ORDI request. I’ve tried that but Sky are sending me round in circles.
So I have 2 questions…
1, Will I still qualify for the reward card if I place my order over the phone?
2, Would Plusnet then be able to raise the ORDI request to get the mismatch fixed?
Thanks in advance
Re: Switching problem
yesterday
There is a process (in ALBERT) for addressing this, though the person you speak with might need pointing at that process.
As for the reward card, you will have to ask when you phone up ... the staff around here probably do not have the knowledge to answer that question.
yesterday
Thank you
18 hours ago - last edited 17 hours ago
You might be able to get that looked at sooner using this form -
. https://www.openreach.com/forms/fibre-broadband-availability---customer-form
Please only use this form if you've already used our availability checker to get
information about broadband in your area and you think that the information provided
isn't accurate or is incorrect.
7 hours ago
Moderators Note
This topic has been moved from Full Fibre to My Order.
3 hours ago
Thanks. I did complete the linked form and they replied.....
2 hours ago
@yipykayay Unfortunately, only your current ISP can raise the ORDI request, and until that is done, you will be unable to switch.
20 minutes ago - last edited 18 minutes ago
If Sky refuse to help you with the ORDI, you can bypass your existing line database issues by ordering an new line installation from Plusnet, get them to arrange Openreach to install the second line and get everything working with Plusnet, THEN just cancel your Sky account.
Doing that also means that you can claim the MoneySupermarket £125 reward card, but there may be additional charges for the provision of a new line (unless you can find a deal that excludes that).
Is the line you are trying to move from Sky to Plusnet, SoGEA via copper landline, or FTTP full fibre ?
