Static IP issue
Rive247
Static IP issue
My service has been active just under a week and i've not been allocated a static IP. I've paid the fee and pressed the button to activate but it still says I have a dynamic IP despite trying this a few times.
I have rebooted my router just to be sure but there seems to be an issue. Thanks
5 REPLIES 5
willcutforth
Fixes: 97
Re: Static IP issue
Now then @Rive247 I can have a look at this for you. I have got it 1 stage further but I am going to try it again tomorrow and see if I can budge it forward again! Sorry for this.
 Will Cutforth
Rive247
Re: Static IP issue
Thanks Will, appreciate the help
willcutforth
Fixes: 97
Re: Static IP issue
I have had to raise it to the network team as unable to do anything with it at the moment. SHould have an update within the next few days Smiley
 Will Cutforth
Rive247
Re: Static IP issue
Hi @willcutforth have you had any progress on this yet? Thanks
willcutforth
Fixes: 97
Re: Static IP issue
Hey there @Rive247 sorry this is my bad, I thought I had replied! Should all be ok, if you can reboot the router all should be ok for you.
 Will Cutforth
