Speed Promise has change since order
L0rdMike
I placed an order on the 15th with a promise min download speed of 50 but now on the website that has changed to 0.8
I do not think its worth me carrying on with the contract if this is the case as our wireless broadband would be faster.
12 REPLIES 12
RealAleMadrid
Fixes: 68
Re: Speed Promise has change since order
@L0rdMike  You need to contact Plusnet as it looks like they have ordered the wrong product.☹️ Those slower speeds could be for an ADSL service so do not apply to a "Fibre" (FTTC or SOGEA) connection.
Fixes: 117
@L0rdMike
Can you post a screen image of the results from the following after hiding your details.
To post a screen image click on the Image.JPGicon above the text reply box.
L0rdMike
Not 100% sure how it works but is it possible that when I did my order I took the last slot in the cabinet?
Fixes: 117
@L0rdMike
Thanks for the information.
While you should get between 57.2 - 77 down on a FTTC connection the problem with your order is shown to the right where it says "Waiting List"
This means there is no capacity at the Cabinet so PN can't place your order - they appear to have provisioned you on an ADSL connection to keep you going.
Are you moving to PN or were you trying to upgrade.
L0rdMike
When I placed the order it showed 77 on the website, is it possible I have taken the last space in the cabinet or have they quoted me the max speed with a full cabinet?
Fixes: 580
Have they ? or was there availability at the time of the order and so OR accepted it but now there is no more capacity ?
@L0rdMike I suggest you call customer services to check whether your order has been accepted
Fixes: 117
@L0rdMike
It's entirley possible that  when you ran the enquiry there was a port available but in between you running the enquiry, placing the order and then PN attempting to place it with OR someone else jumped in and got the slot.
Are you moving ISP? If so, that will create a port when you move but once again someone else may jump in first.
Login to your PN Members portal and see if there are any Question under "My Order"
L0rdMike
If the worse comes to it and its terribly slow I can reject it as its not the speed I ordered right?
Fixes: 117
@L0rdMike
As suggested by @MisterW  & @RealAleMadrid you need to phone Customer Services to get final answers on this.
Any Open questions on your Members Portal with detail?
Once again, are you moving ISP? If you cancel with PN you'll have to stay with them. If you go with PN ADSL they'll happily upgrade you when an FTTC port becomes available. You just need to keep checking morning, noon and night and as soon as it shows available jump in with an upgrade request via your Members portal.
James30
Fixes: 32
@L0rdMike - I've left you a ticket here @ https://www.plus.net/wizard/?p=view_question&id=240725820 because my message has a bit of account specific info on it but feel free to paste it on here so we can chat on here about it.
James - Plusnet Sheffield
L0rdMike
Is it possible when I placed the order that I took the last space available or is that stage of setting up broadband not done yet?
ClaudiaG23
Fixes: 25
@L0rdMike As James has advised, we've got a date of you going live, and it is showing SOGEA. We'll need to wait for this date to make sure it is you that has been given that last slot.
 Claudia Garner
