Sanctuary warden alarm system
New_ff2025
Good afternoon. I want to ask a question if I may. I have a Sanctuary warden alarm hardwired system in my property and I'm with Sky at the moment full fiber with a live phone line but Plusnet doesn't come with a live land line connection so I'm a bit concerned that my warden alarm box won't work when my land line is disconnected.
To be honest I never used my land line phone, never used it for last few years when I went full fiber . Anyone else use a sanctuary warden alarm that uses Plusnet with a disconnected phone line? I am getting Full Fibre 145
Plusnet Hub Two FTTP
58 REPLIES 58
Fixes: 357
Re: Sanctuary warden alarm system
@New_ff2025 Welcome to the forum. To be honest, if you are thinking of moving to Plusnet, you are better asking the alarm provider if they have a suitable alarm which works without a hardwired PSTN connection. They will have to have such a facility when the PSTN system is closed, anyway, irrespective of whom your ISP/Communications provider is.
The current expected switch off time for the 'old' phone system is December next year.
New_ff2025
Thanks for your reply. I have emailed sanctuary but haven't got a response. I guess I'll just have to wait to see if my warden alarm still works without an active landline.
I know I have a 2 week cooling off period so if it doesn't work I'll cancel Plusnet
Fixes: 357
A word of warning, that 'two weeks' is from Plusnet acknowledging and accepting  your order.
New_ff2025
Ah ok, thanks
Fixes: 466
@New_ff2025
I’m surprised that Plusnet have accepted an order from you. Did you tell them that you have an alarm when you signed up? Previously I have read of such orders being directed to BT.
Fixes: 466
Moderator's note:
Thread moved from Full Fibre to  My Order
New_ff2025
Hi, no I didn't tell them I had a alarm system when I joined. I think I'm just going to cancel Plusnet and go back with Sky. I don't need the stress 😔. I'm waiting for a reply from twitter from Plusnet about this
Fixes: 357
Fair enough @New_ff2025 .
You'll be waiting a while for a Twitter response.
New_ff2025
I can't find any live chat with Plusnet
Marsh
Fixes: 41
Hey @New_ff2025
We no longer offer live chat support online; it could take some time, as we have a large number of messages to respond to. Once you find out if the Sanctuary alarm is compatible with VOIP, it may be best to explore EE, which can provide FTTP and VOIP services. Alternatively, if you decide to stay with us, consider looking into the possibility of finding a VOIP provider.
Josh
Fixes: 357
There is no live chat, it is phone, these forums or snail mail only.
New_ff2025
Thank you for your reply. Sky uses voIP which I'm using at the moment. Plusnet doesn't use voIP. I don't want to spend more on VOIP services as by the time all the costs are added I may as well stay with sky
Fixes: 105
@New_ff2025
Can you confirm you are currently on a VOIP service from Sky and that your copper landline is no longer in use?
If so, you know Santuary Warden alarm systems work with VOIP so it would just be a case of finding a VOIP provider and transferring your number.
If you don't use VOIP for anything else you could set up an account with the likes of A&A with a generic number. Once running you would simply change the settings in your alarm system to the new number.
https://www.aa.net.uk/voice-and-mobile/voip-information/
Or am I missing something?
New_ff2025
Yes I'm using a VOIP service with sky at the moment. I got a new ONT box put in a year ago.
I don't use my landline phone at all but I have the base left in just in case I need it on for sanctuary warden alarm system to work but I'm not sure if the warden alarm system needs an active landline as I think the alarm box uses a SIM card . I have a Tynetec Advent XT
