Router not arrived
Dp22
Router not arrived
My connection date is supposed to be tomorrow but I’ve not received my router. As I’m working from home it is essential that I have access to the internet. I’m assuming (rightly or wrongly) that my current provider won’t switch me off until I’m connected with you?
4 REPLIES 4
Mook
Seasoned Champion
Fixes: 9
Re: Router not arrived
Hello @Dp22 Welcome to the forum. Sadly that's not the case. Your existing ISP could cut you off at anytime after midnight tonight. With your service not going live until tomorrow there is still time for your new router to arrive. Not what you want to hear but you should have minimal downtime, if any.
Dp22
Let’s hope it arrives!
bobpullen
Fixes: 330
@Dp22 your router will be dispatched from the warehouse today and will likely be with you tomorrow.
Dp22
Ok thanks
