Problem with ORDI
Fixes: 1,662
Re: Problem with ORDI
Sorry about this. Our routers are usually automatically sent once an order’s confirmed. Unfortunately, in your case the order completed rather quickly as I expedited it.
With any luck, you’ll get it tomorrow or Saturday.
cdfm
Man thanks to everyone who helped - especially ++Gandalf++
The router arrived this afternoon; I plugged it in, configured it, and it's working very nicely. Now I just have to work on an optimum position (old flat, thick walls), but I have plenty of experience with that.
Moderator's note: Fix moved to the correct post
