Order delayed
- My Order
- Re: Order delayed
Order delayed
20-08-2022 12:10 PM
1 REPLY 1
Re: Order delayed
24-08-2022 9:38 AM
Hiya @emlou289,
I'm really sorry for the delay with your order and I can imagine the confusion as well as worry this is causing, especially when you are due to work from home.
Sorry for the delay in getting back to you, we're quite chocca at the moment, I can see the order has completed and you have an active connection. Can I check you are up and running at your side?
Message 2 of 2
(788 Views)
