On holiday when service is enabled
Tomsk1973
Hi, I've just switched from BT to Plusnet but the switch over will happen when I'm away from home. My question is : Do I wait until I'm back to plug in the Plusnet Hub or do I plug it in and connect it before I go? Does it even matter? Thanks for any advice in advance.
10 REPLIES 10
Fixes: 1,491
Re: On holiday when service is enabled
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 105
@Tomsk1973
Personally I would disconnect the BT router before leaving and then add the Hub2 when you get back.
What you must do is leave the ONT powered up.
Fixes: 357
@bmc 's 'ONT' comment applies if you are having Full Fibre - if it is FTTC, just either leave it as it is, and do the switch when you return, or, as he says, unplug the BT hub, and set the PN one up on your return.
Fixes: 105
@jab1
Thanks -  I was sure I'd seen "fibre" in the post.
@Tomsk1973
I assume you know you'll lose your phone line.
SammyM
Fixes: 101
Hiya @Tomsk1973
Leave the ONT power on and just plug our router in before you leave Smiley When you come back you should be good to go.
 Sammy M - Sheffield Team
Fixes: 357
@SammyM  - So the OP is on a Full Fibre connection?
SammyM
Fixes: 101
I can't confirm what service they are on over here. I can however tell them to the above so if they do have FTTP they will know they have an ONT Smiley
Fixes: 357
Fair enough - but I thought @bmc had already said that - when he too didn't know whether it was an FTTC or FTTP provision.
Tomsk1973
Hi all, yes I have an ont box. Thanks for all the advice. I'll just unplug the bt box before I go away then.
Thanks all
Tomsk1973
Ooh also there's no phone line so I don't need to worry about that. Great community response thanks!
