No speed increase
Herb
No speed increase
So I upgraded to fibre extra and had an email to say switch over on 19th April,  has someone forgotten me as no  speed increaseat all.   I should be seeing 54 minimum
5 REPLIES 5
Fixes: 251
Re: No speed increase
Have you had an email to say that the change has completed?
What are you switching from / to?
Herb
Exisintg PLusnet standard fibre to fibre extra, new router delivered and sorted, email said switch over would be 19th
Fixes: 251
Can you find and post the router stats to here please?
Herb
Herb
Just been told 25th now,  thanks for getting back to me
