No Activation
Owensoc
No Activation
My broadband was supposed to be activated on the 1st but I have heard nothing for 2 days.
47 REPLIES 47
Fixes: 387
Re: No Activation
If you connect the Hub and try it, what happens?
Owensoc
Re: No Activation
Orange ring
Fixes: 387
Re: No Activation
Steady or flashing?
Owensoc
Re: No Activation
Steady
Fixes: 387
Re: No Activation
Don't know if you have checked - what username is showing on the Hub. If it is '[email protected]', try rebooting the Hub.
Owensoc
Re: No Activation
I will try thank you
Owensoc
Re: No Activation
It still has an orange ring after reset, it says on my account that they are still working on my activation. But there has been no update since the 1st when it was last delayed too. I will keep waiting and trying to see what i can do. thanks
Fixes: 387
Re: No Activation
I would give them a call tomorrow morning and ask what the hold-up is - you have a connection, so it is a PN issue.
Galadriel
Re: No Activation
Hi @Owensoc
I'm really sorry to hear about your delay, it looks like the FTTP order is delayed in planning. We've not been given an activation date yet as there's been no full fibre connected at your address before so they need to do checks and plan the work, the review date for this is the 12/12/23. Once this has been done, they will proceed with implementing the solution and installing the cables.
Fixes: 387
Re: No Activation
So, this is an FTTP installation - if I may ask, what service, if any, does the OP have, and is it with Plusnet?
Owensoc
Re: No Activation
Plusnet full fiber 500. When purchasing it said that my address was able to be remotely activated. It was originally supposed to be active on November 30th.
Fixes: 387
Re: No Activation
@Owensoc What did you have previously, and with whom? Have Openreach installed your ONT?
Owensoc
Re: No Activation
I’ve just moved into a new to me rental, there is an open reach box that has been there from before.
Fixes: 387
Re: No Activation
Ah, OK. You say 'openreach box' - do you mean a standard phone master socket, or an ONT as below?
