New customer - already Fibre ready
Goose1
Hi, have just signed up and been given an activation date a few weeks away as the system didn't detect my Openreach ONT connection. Don't think I need the engineer appointment, can I be activated quicker? I'm certain that it's connected and working as it's my current primary connection. Thanks
15 REPLIES 15
Fixes: 371
Re: New customer - already Fibre ready
Who are you currently with, @Goose1 ?
Goose1
Hi John, I'm with Vodafone on their full fibre FTTP
Fixes: 371
@Goose1 In that case, I don't quite understand why the system didn't detect your ONT. It must be active for you to get your current service, in which case, the change is remote, usually within 2-3 days
Fixes: 568
@Goose1 whilst its possible that the extended transfer date is due to not detecting the ONT , its also possible its due to 'anti slamming' rules in that there is a minimum of 10 days for a working takeover.
I'd give customer services a call to find out why ?
jgb
Champion
Fixes: 22
Vodaphone use both Openreach and City Fibre (and possibly other Altnets) to provide FTTP.
Is it an Openreach ONT you have or another nertwork's? Plusnet, being a BT company, only use Openreach and if the ONT you have is not an Openreach one then another will need to be fitted.
Fixes: 371
@MisterW But if the OP used the GPL route, does the 10-day anti-slamming procedure apply?
Fixes: 371
@jgb VP's site says they use OR?
jgb
Champion
Fixes: 22
@jab1 If I look on the CityFibre site and put in a postcode where I know City Fibre operate, Vodaphone are one of the ISPs listed. A quick look at the ONT the OP has will confirm if it Openreach or not.
Fixes: 371
@jgb The OP says ' as the system didn't detect my Openreach ONT connection. '
Fixes: 109
@Goose1
Does the ONT look like this?
https://support.aa.net.uk/Openreach_FTTP_ONT
Goose1
Will do - just thought it might be easier to ask here as I had seen other posts about it from Google.
Yeah its an Openreach ONT
Goose1
Spot on, the top image
Fixes: 568
Yes, that's when it does apply. When the order is placed there has to be time for notification to the losing supplier and any response (to them) by the customer to be able to stop the transfer.
Fixes: 371
Fair enough, @MisterW , but the OP says they have been given a date 'several weeks away' - don't know how many, but under those rules a fortnight should be the maximum?
