New build
carldale123
New build
Hello,
I will be using plusnet as my broadband provider, new build house, already on the database etc, however I want to make sure my broadband is active near enough for me moving in, I have a completion date which is for 2 weeks time however I know I’ll need the router sending out to me… how would I order broadband but get the router sent to my current address where I live with parents (I’m a first time buyer) just so that when I go I can plug it in and hopefully be active?
10 REPLIES 10
Fixes: 118
Re: New build
@carldale123
I assume this is a new account.
The PN router fits through a standard letter box. It is sent 2 03 3 days before the account goes live. When it's dispatched you get a tracking number for Royal Mail.
If you've not yet ordered then ask for the router to be delivered tp your parents. If already ordered then phone and ask for a change to the delivery address.
carldale123
Re: New build
Thank you for the response, yes this will be a new account, and it will be done online as I can get a rewards card too which is a bonus, if I order online in the next couple days should I just then ring up and speak to someone or should I try and order it all on the phone ?
Carl
markhawkin
Champion
Fixes: 22
Re: New build
Getting the router will (probably) be the least of the issues.
Have Openreach fitted an ONT as part of the build?
If not, then the wait for that to be done will allow enough time for the router to reach you.
carldale123
Re: New build
Hi Mark,
Luckily one has already been fitted
Carl
markhawkin
Champion
Fixes: 22
Re: New build
That's one thing done then.
If you had another router (with an Ethernet WAN connection) available, it may be possible to use that pending the arrival of the Plusnet device.
Fingers crossed!
Fixes: 587
Re: New build
but is it powered up ?
I dont know about new builds , but on normal FTTP orders where an ONT is already shown as present, Openreach run a test to check its working. If the test passes then the order progresses as a remote activation, which takes 2 or 3 days. If it fails, then the order requires an engineer visit which can often take a while.
I would hope, that on new builds, Openreach have already tested the circuit when they installed the ONT but I wouldn't put money on it...
carldale123
Re: New build
Good morning
Yes when I visited site the other week it was powered up with a power indication light and “PON” light both as green just LAN and ALARM no lights due to no router installed ?
Fixes: 587
Re: New build
That's really good news. It should then be possible for any order to be placed as a 'remote activation' i.e no Openreach engineer required.
carldale123
Re: New build
If I called to place the order would they be able to direct the router to my parent’s house? And be able to apply the rewards card also?
Fixes: 587
Re: New build
They shoudl certainly be able to redirect the router delivery.
As for the reward card, you would need to check with sales
