Long activation delay
Cutterschoice
Placed a new order on 19th July activation date was the 31st which changed to 1 August. Received the router etc. The 1st August came and went, on the 2nd had a strange message saying an order had been placed you don’t need to do anything, I just assumed it’s the weekend it’ll sort its self out.
This morning I’ve had an email saying the activation date is the 18th August. No idea what’s going on, is anyone able to advise, thank you.
9 REPLIES 9
Fixes: 389
Re: Long activation delay
@Cutterschoice This sounds a little strange, I would suggest ringing Customer Support and see if they can give you an explanation.
Fixes: 585
@Cutterschoice are you moving into a new property ?
It sounds like there was a cease on the existing connection which prevented the original order being placed by Plusnet. This completed on the 1st Aug and an order was able to be placed. This is now subject to typical lead times for Openreach engineering
Cutterschoice
Good morning, not moving, had some issues with an EE transfer, where I had to cancel EE, then plusnet to then return to plusnet, was a bit of a mess.
The new order was after sorting things out with PN over the phone, so we’re aware. I’ll call them as soon as they open, really can’t deal with another 2 weeks.
Fixes: 389
Ah, the dreaded PN/EE switch fiasco.
Fixes: 585
that's probably where the cease came from ...
Fixes: 251
“really can’t deal with another 2 weeks.”
That is the typical BT Openreach lead time for service provision.  Is this like for like (SoGEA in place of FTTC) or a new install (FTTP)?
If SoGEA then try requesting an expedited order given that you are in this situation out of (not detailed) issues associated with an EE migration.  These cost an ISP ££ so they are reluctant to do them, but you can ask.
If it’s FTTP then it’s when BTOR engineers are available.
If teaming with Plusnet means a new user account, you’ll either need a new Plusnet router or get the serial number of the existing one switched between accounts.  Do you have email on the existing account and if yes has it already been migrated to Greenby?
Cutterschoice
Wish I didn’t call PN, there’s some sort of issue with the line in cancelling the previous provider PN/EE, so no choice but to wait.
Customer service used to be really good, I explained a few times I didn’t understand why, also zero contact other than an email this morning saying another order had be placed and a change in activation dates to the 18th. Then told I was emailed about the issues, which I wasn’t.
It’s fine if someone could / would have just explained it to me so I understood the issue, I’m almost regretting trying to come back, how do I know everything will be up and running on the 18th, just tried to sell me some 5g package. Ended up hanging up which I never normally do just can’t deal with it.
dparr1959
Ring them up and threaten to move anywhere but EE or BT and someone might do something thing if you're lucky.
I Moved to Vodafone which is also cheaper after a failed move to EE from Plusnet that dragged on for nearly a month and no one from either EE or Plusnet did a thing to help.
Move date confirmed to Vodafone and on the day given by Vodafone the transfer happened .
Looks like to me Plusnet & EE decides when the migration happens regardless of any date given to you.
They don't keep you informed and leave you in the dark for weeks in the hope you won't complain and if you do just fob you off again and again.
Cutterschoice
Hopefully all sorted now, although no text or email to confirm activation was complete, had to call this morning to confirm. Can’t check as I’m away until Thursday, just hoping the correct profile has been set up.
I’m just gonna say I’m really disappointed by the whole process, it’s fine to delay things, things happen, the lack of communication is just poor and makes it frustrating. Anyway hopefully Thursday when I’m back everything is working, thank you to the ones that answered my calls staff are helpful when calling up.
