Installation delay?
laurenk1709
Installation delay?
Hello,
I was due to have my engineer appointment and activation on the 28th November, but received a text message on Friday informing me of the delay to my order, with no further details. As the engineer needs to come to my home to install a phone socket, it would be helpful to know what date I now need to book off from work instead of Tuesday. As I work full-time away from home it is not helpful to be told my service is delayed and not be provided with a new date.
Thank you
10 REPLIES 10
laurenk1709
Re: Installation delay?
I’ve now just noticed that it says on my account that the service can be set up remotely so an engineer visit is not required. This is not true. I do not have a phone socket, and I have paid the ~£50 for an engineer to come down and sort this. Please tell me this has been booked and I haven’t wasted my money.
Longliner
All Star
Fixes: 8
Hi Lauren -- These snags on installation are all too common. The Pnet staff monitor these forums from time to time but in view of the urgency I would advise you to call them as soon as you can. Have your details ready. Best of luck!
Mike
adamwalker
Fixes: 223
@laurenk1709 I wonder if you've checked the broadband order as those often don't require an engineer visit.
I've checked this for you and confirmed everything on a ticket for you here: https://www.plus.net/wizard/?p=view_question&id=238555436
Please take a look when you can and let me know if you have any questions.
Adam
 Adam Walker
Fixes: 582
They do if as the OP says, there really is no phone socket...
laurenk1709
Hi, Adam. Thank you for your help and confirming the date is still as expected. Should I just ignore the text about the delay, then? Not sure why this was sent in this case.
Also, yes, when I check the broadband tracking it says there is no need for an engineer, which made me worry I would not get a home visit despite the lack of phone socket 🥲.
laurenk1709
It looks like the previous tenant removed/plastered over the phone socket when moving out 😭
Fixes: 582
Problem is that Openreach will have no knowledge of that, their systems will say there is a socket.
laurenk1709
Since I’m paying for the installation of a completely new phone line, this should be okay, no?
Fixes: 582
It SHOULD be,  but it depends what Openeeach's systems say. If the previous line was disconnected at the exchange, then OR may think they can just reconnect it! The engineer SHOULD check the line and detect there's no master socket connected...
MatthewWheeler
Fixes: 503
Hi @laurenk1709
I can see your appointment is due for this morning
Let us know how you get on!
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
