How do I reply to a plusnet support email?
mrdanoneill
There is a button to view their reply but no way to reply to their message.
Hillariously, their message tells me to contact BTOpenReach complaints, to complain to them by email.... On the phone to plusnet (the call that resulted in their message), I explained this morning that I emailed BTOpenReach weeks ago to explain that their / plusnet's failed install of fibre to my house has resulted in a hole in my house that rain is getting in and destroying my cavity wall insulation, it was thousand of quid to get that installed and its all soggy and clollapsing down in the cavity. It'll cost thousands to get it repaired and I AM GOING TO COURT over this if I have to. But bt wont reply and when I call plusnet they just tell me they'll contact bt, only to tell me hours later to contact bt on the same email I've already tried.
And hillaiourly still: the only reason there is a hole left - the engineer from bt was a bit distracted cos he found that our village was in no sense live for full fibre, that the installers hadn't done the config in the datacentre/exchange and that loads of kit was missing from racks there. Then he left in a hurry. In the meantime my neighbour got full fibre done two days after - a neighbour who come off the same telegraph pole as us.
4 REPLIES 4
Fixes: 118
Re: How do I reply to a plusnet support email?
@mrdanoneill
Have you complained to OR in writing?
There is an online form you can fill in. See
https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach/complaints-policy
Fixes: 480
Moderator's note:
Thread moved from Full Fibre to My Order
mrdanoneill
Hi Brian,
Yup, thats the form I filled out a long time ago. I explained that to Plusnet this morning that I'd already used that form over a week ago and had no reply or anything (just default confirmation "we'll get back to you in 48hrs", that's why I found it odd that they (plusnet) emailed a few hours later this afternoon and directed me to the same contact at BT.
And then you pointed out the same form Smiley
Doesn't matter, at some point you have to just give up getting stuff sorted out rationally and just wait for serious damage and prepare to get compensation. I spoke to plusnet again just now and they explained that they really have zero access to BT other than to point poeple at that form.
I have videos of the soaking wet insulation and the hole in my wall, and copies of my emails and screengrabs of my form filling out and records of the calls upon calls. If the insulation is as wrecked as it looks through the hole, then someone's paying to fix it and it aint gonna be me...
Thanks,
Danny
Fixes: 253
Your situation seems grim.  Given the risk, have you considered taking your own remedial action and sealing the hole your self?  If this were to go to court, what you did / could have done / did not do to mitigate the damage might be considered in any recompense award.  It might be a wise move to get the damage wall repaired sooner rather than waiting, to avoid further detrimental damage to the cavity installation.  You can then argue about the current damage whilst avoiding it getting worse.
Plusnet passing this matter back to BT Openreach is the correct process.  BT Openreach, not the ISP is responsible for any damaged caused by BT Openreach (or their sub-contractors) during an installation.  Do you recall, was this the work of "real" BTOR staff or one of their subcontractors (J.C. Quinn or Kelly Communications)?
You might need to email the CEO of BT Openreach direct to get a prompt response.
As for the neighbour, was that a BT Openreach installation or some other Altnet provider?
