Full fibre upgrade showing error
maxheadroom
I upgraded to full fibre yesterday 3/4. I received an email a few hours later saying product change now complete, but change not showing in account. It says there's an error.
20 REPLIES 20
Fixes: 1,495
Re: Full fibre upgrade showing error
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 374
@maxheadroom Does your FF connection work though? If so, ignore such 'errors', they are a quirk of the accounting 'system'.
Fixes: 1,660
Hi @maxheadroom,
I can see it's just taking longer than usual for your account to reflect the completed product change.
We're definitely aware and we'll sort it as soon as possible. This won't affect your service in any way.
maxheadroom
My fibre connection is working fine. It's just my bill is due tomorrow 5/4, and it would be nice if it was correct rather than wait for an adjustment the following month.
Fixes: 374
Your invoice for 5/4 will have been generated about a week ago, and cannot be 'adjusted' - you will have to wait until next month.
Fixes: 1,660
We don't bill accounts prior to the bill date and we won't generate the bill in this case, until the change is fully complete.
Fixes: 374
@Gandalf Is that a change of policy, or have I been under a misapprehension for many years?😀
Fixes: 1,660
@jab1 It's always been the case for as long as I've worked here.
Fixes: 374
OK - I'm wrong then. 😉
Fixes: 1,660
@jab1 You said it not me Tongue But at least you know moving forward!
maxheadroom
Any update? Account still showing error.
Fixes: 1,660
I've checked and we're still working to fix the issue - shouldn't be too much longer. Sorry for the delay.
maxheadroom
Upgrade now showing but monthly cost showing £43.20 should be £26.99.
maxheadroom
Just received a bill for £41.44, which is obviously incorrect.
