Full fiber upgrade, no router
Glesgadave
Engineer came out this morning to install full fiber line. An hour after he left then Internet cut off on the old line and I've not been supplied with my new router yet to plug into the full fiber line.
So I'm stuck with no Internet, with an essay due in a week, and no idea when the new router will arrive 🤷‍♂️
9 REPLIES 9
Fixes: 334
Re: Full fiber upgrade, no router
Which router have you currently got?
Glesgadave
The hub 2
Fixes: 334
Then, that is what your 'new' one would be - did the engineer not test the FF connection was working before he left - he should have?
RealAleMadrid
Fixes: 66
@Glesgadave   That's the correct router, all you need is a Cat5e or better ethernet cable to connect the Hub2 WAN port to the ONT (The box that Openreach have installed).
Fixes: 457
Moderator's note:
Thread moved from Broadband to My Order.
Glesgadave
No he didn't test against the router at the time. Just said plusnet would send a new one. So I just plug thr hub 2 in by ethernet cable? Is it to the port port eith the red writing under it?Huh
Glesgadave
Amazing, wish the engineer had just said this earlier 🤣🤣
I have an ethernet cable here but I'll order an upgrade now as well.
Thank you!!!
Fixes: 334
He should have done - that is part of the installation process - and yes it is the red port.
Glesgadave
All sorted. Thank you!!
