Fibre install caused mould
FIXEDTopic Options
- My Order
- Re: Fibre install caused mould
10-09-2023 11:40 AM
I recently had fibre installed in my house by Plusnet, during which they drilled a hole in my wall facing the street. Since then black mould has steadily grown around the area it was installed. Can I ask Plusnet to come and properly seal the hole to stop the moisture coming in?
Fixed! Go to the fix.
Message 1 of 3
(1,337 Views)
2 REPLIES 2
10-09-2023 12:30 PM - edited 10-09-2023 12:31 PM
Plusnet did not install fibre to your property, this was done by Openreach.
Workmanship complaints are best directed to them, see https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach/complaints-policy
Message 2 of 3
(1,320 Views)
10-09-2023 12:55 PM
Much obliged, I've contacted them now.
Message 3 of 3
(1,310 Views)
- My Order
