Fibre Upgrade and Plusnet Hub One - "Pending"
FIXED- Subscribe to RSS Feed
- My Order
- Re: Fibre Upgrade and Plusnet Hub One - "Pending"
07-02-2018 1:16 PM
Hope you can help....I placed an order to upgrade from ADSL to Fibre on 30th Jan and received email same day confirming a such.
However, today (8 days later) in the "Member Centre > Account Details" screen, i'm seeing:
- Unlimited Fibre Broadband - "Pending"
- Plusnet Hub One "Hardware dispatch" - "pending"
Am I being too optimistic expecting these to have progressed past "Pending" ?
Thanks.
Fixed! Go to the fix.
07-02-2018 1:18 PM
07-02-2018 2:03 PM
Thanks for the speedy reply...
14-02-2018 1:17 PM
i received email overnight saying "your broadband product change is now complete" - Fibre Unlimited.
However, i still have my old plusnet ADSL modem/router plugged in and it was working when i left for work this morning.
My questions are:
1. Should I of setup the One Hub before today? (I didn't because i assumed it wouldn't work on ADSL)
2. If fibre has been activated, how was broadband working this morning on my old plusnet ADSL modem/router.
Thanks.
14-02-2018 1:19 PM
@staley84 We change your account early so that when the engineer completes the work you'll receive the higher speeds straight away.
With regards to the Hub One you can use it before the work completes as it works on standard and fibre broadband.
14-02-2018 1:25 PM
@MatthewWheeler - I see....
So i'm guessing that first thing this morning i was still on ADSL and that the BT engineer work will hopefully complete sometime today.
Hope leaving the existing ADSL modem/router connected doesn't mess with anything....I swap over to the OneHub this evening.
14-02-2018 9:39 PM
Just a quick update...
Got home this evening and ADSL broadband not working (as expected due to switch to fibre)
Had message on anwser phone from Openreach engineer saying the the change to fibre had been made.
Disconnected old ADSL modem/router and plugged in Hub One.
All connected with 5 mins.
Currently getting ~37/8
Thanks for your help.
21-02-2018 4:08 PM
Hi staley84,
I'm glad to hear your issue has been resolved.
if you need us for anything else please don't hesitate to give us a shout.
Thanks.
- My Order
