Fault in new build property
- My Order
- Re: Fault in new build property
18-06-2026 6:55 AM
18-06-2026 7:15 AM
with developer. Clearly a snag issue that they must remedy.
Visit https://www.ceoemail.com/index.php, for relevant big wig e mail!
18-06-2026 7:32 AM
I have not been able to activate my service as openreach determined there is a fault.
@poppy34747 have you placed an order with Plusnet ? and is this a Full fibre order ? (I guess so as its a new build?)
If so, then the cable up to and including the ONT are Openreach's responsibility. As part of the ordering process, Openreach will do a remote test of the ONT, if this passes they will do a remote activation. If it fails for any reason e.g cable fault, then Openreach will schedule an engineer visit to fix the problem.
NB are you sure the ONT is powered up ?
18-06-2026 9:15 AM
18-06-2026 9:21 AM
Short of ripping your new house to bits the only other option is to get Openreach to install the ONT in a different location, in the same way as if the builder had not provided the internal fibre.
18-06-2026 9:32 AM
I would contact the NHBC to see if they can help, the developer has a duty of care for the first two years of owning a new build.
18-06-2026 9:47 AM
18-06-2026 11:11 AM
There are two issues here, that is, the housebuilders responsibility and getting you on line.
Not withstanding the blame issue, how was it left with Openreach? Did they give you contact details so that you could get them back once this was resolved? If not you need to contact Plusnet and arrange for them to arrange for Openreach to return to repair the current fibre, probably by moving the ONT to an accessible location new cabling wise near a power socket, then connecting new fibre between the ONT and the external CSP.
There should be no charge for doing this.
If the ONT is installed in a less convenient location you will need to negotiate redress with the builder.
18-06-2026 11:55 AM
Get your lawyer involved. If the fibre optic is built into the house then your builder has supplied a house with problems. Their problems!!!
18-06-2026 12:21 PM
As pointed out earlier, there are two issues.
The question is does @poppy34747 want to spend months in legal arguments and having his new property taken apart and redecorated to replace the existing faulty fibre cable, or take a more pragmatic approach in order to get on line as quickly as possible?
18-06-2026 12:39 PM
@poppy34747 wrote:
As the cable is behind the skirting/kitchen cabinets it can’t be fixed. Bellway’s view is that it worked for 2 weeks so isn’t their issue.
It might well have worked for a short time, however fibre 'cables' need to be installed with more care than copper wires. Fibres are fragile and are not forgiving of tight bends or other stress points. If the fibre has been run through a pinch point, stress arising for the occupancy / use of the property could have pushed the pinch point to bring about a fracture in the fibre.
There is questionable wisdom in burying an optical fibre into the fabric of the building. With a buried metal conductor, one can use a cable detector to ensure that where you want to place that nail to hang a picture, is nowhere essential infrastructure. Such is not the same for a glass fibre 'cable'. It brings about the consideration of is the installation fit for purpose and environment?
18-06-2026 1:55 PM
This is true but what about plastic 'Speedpipe' used almost exclusively for plumbing nowadays !! A friend of mine knows to his cost you cant detect where it is hidden in modern new builds or alterations in older homes. Hanging pictures has become something of a game of Russian roulette !!!!
18-06-2026 2:38 PM
Detection of plastic water pipes is possible. I have no idea how good they are, but I suspect the prices of capable detectors would be higher than the average DIYer might want to pay.
Delayed Fibre Activation - Faulty Installation (Need Staff/Openreach Liaison)
a month ago
- Look into my order and reply here with the current official status/notes from Openreach?
- Provide me with a specific Fault Reference Number or Ticket ID that I can pass on to my developer?
- Advise on how we can get Openreach to liaise directly with the site developer to resolve the physical fault?
Re: Delayed Fibre Activation - Faulty Installation (Need Staff/Openreach Liaison)
a month ago - last edited a month ago
Moderators Note
Two topics on the same subject have been merged.
- My Order
