FTTP woes
Fixes: 116
Re: FTTP woes
@dazgee1965
The Checker didn't say one way or the other about potential problems. The message about the duct was simply telling the engineer what was in the ground.
When I got FTTP the Checker said UG feed - proven clear. I knew what this meant as the chamber is in my neighbour's garden and I was chatting to the guys as they did the work. If they had easy access to the duct at the house end they put a rod through to check. If it was clear they then left a draw rope in place. Five out of seven houses were checked with only one having a slight problem which they were able to push past from the chamber end.
dazgee1965
Re: FTTP woes
Well the Openreach engineer didn't come back this morning, what a surprise.
@Gandalf
I've left a note on my question on my account.
I know it stated it's on hold until 7am on the 14th but could you check to see if there is an update from Openreach?
Thanks.
Fixes: 1,662
Re: FTTP woes
I've spoken with our suppliers helpdesk and from what they can see, the engineer visit is booked for this afternoon.
Really sorry about this.
dazgee1965
Re: FTTP woes
@Gandalf
Thank you for the update I really appreciate it.
No need to apologise, it seems like Openreach hadn't updated the system you use with them so there was no way of Plusnet knowing 😁
dazgee1965
Re: FTTP woes
I'm now connected and loving the speed.
@Gandalf thanks again for your help.
The Openreach engineer whose names I forgot to ask was on the ball and had a clue.
He even removed the old external copper cable so I can tidy up inside.
If he had been the one sent to do the job originally I would have been connected last week but hey ho.
I honestly did think this would drag on so that's me proven wrong.
Once it was up and running I setup a TP Link router and he was interested in it and I think they've gained another customer.
Fixes: 116
Re: FTTP woes
@dazgee1965
Excellent news.
As you got connected today I'm assuming the engineer was able to push through the duct blockage without any digging.
Did you get your ONT sorted as well?
iannewson
Fixes: 5
Re: FTTP woes
Might be worth sending the Openreach Engineer a thank you https://www.openreach.com/help-and-support/thank-an-engineer-form
dazgee1965
Re: FTTP woes
@bmc
Yes the duct was fine he had no problem running the fibre.
He used what looked a coil of thin metal with an attachment on one end to hook on the fibre cable, I pulled it through for him when I saw it poke through the duct outside my place.
I thought it was a neat gadget.
The ONT is fine it's behind a desk and out of the way.
Fixes: 1,662
Re: FTTP woes
Awesome. Glad that your FTTP’s up and running now! Cheesy
I don’t think I actually did anything of value, but then again I get that a good explanation and keeping in touch is almost as important as sorting an issue itself.
Let me know if there’s anything else you’d need help with.
