Early activation
aaron_lp3
Early activation
I’ve received my hub today I work from home but need the internet as mobile data is not strong enough. Can I get connected today ? Any help would be much appreciated.
Thank you
5 REPLIES 5
Fixes: 392
Re: Early activation
When are due to connect?
aaron_lp3
The 12th of this month
Fixes: 392
If that is a confirmed date - only 5 days away - then I suspect that is when it will be switched on. You could try calling, or just possibly one of the Help Team may pick this topic up and see if they can do anything.
aaron_lp3
Thank you very much I’ll try that. Appreciate the help Smiley
adamwalker
Fixes: 223
Hi Aaron, we won't be able to bring the activation date forward I'm afraid.
Everything should go to plan on the 12th but do shout up if there's any issues at all.
Adam
 Adam Walker
