Congested duct / unadopted road
tf12
Hi - current contract (fttc, unlimited fibre extra) is coming to an end and have been looking at full fibre / fttp. The BT Wholesale availability checker says it's available, but with a 'congested duct'. Also we're at the end of a cul-de-sac where the last 5 properties are unadopted (probably 20m to the 'adopted' part of the road). Had an online chat (on X) with support who confirmed they can provide the service.
My worry is if I order the service if there's a problem it'll only become apparent on the installation day - anyone have experience of this situation?
46 REPLIES 46
Terranova667
Fixes: 8
Re: Congested duct / unadopted road
Hi, sadly when it comes to Openreach you can never predict anything, I have been waiting over two months so far for my FTTP installation, in what seemed to me to be a straightforward install based on the BTW checker turned into a Survey required and delay after delay, Openreach needing to install 70m of new ducting and last week claiming they can't start until September, I find out this week if it can be brought forward as September is a pee take but will see.
You can only make the order and see what happens just be prepared for what could be long delays, you will be kept on your old FTTC contract until everything is up and running on FTTP so you won't lose anything, but I would ask staff about your contract situation if it's already coming to an end, for me i'm still within so I don't have that to deal with.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 118
@tf12
If you want FTTP all you can do is press the starting button and hope for the best on the day.
Due to most installs being different you can never tell what's going to happen until the day.
One thing you could check is the following. Full Fibre shows up as WBC FTTP - what does it say over tothe right of this - available, One stage or KCI2
tf12
Hi BMC - it says Available, and FTTP Install Process 1 stage
Fixes: 118
@tf12
When the backbone network is being installed they do a check on property connections to see if there are any obvious problems. For example, a KCI2 note means a survey is required before the install. They don't spend a lot of time on it as any problems are only problems if an order is placed.
It appears all they noted for you was a congested duct. This is not unknown and potentially can be cleared on the day. If not, installation is delayed while a specialist team gets called into clear the duct - hopefully without digging.
tf12
OK thanks for the info, will put an order in and cross fingers...
Bonus question, will the installer (assuming it can be installed) insist on there being a double-socket available nearby? If so does anyone know how long the power cable is?
Fixes: 387
@tf12 The power cable is 1m in length, and it doesn't need to be an actual double socket - I just plugged a four-gang adapter into a single socket.
Fixes: 118
@tf12
One way of clearing a congested duct is to cut the original incoming copper wire and use it as a draw rope to pull the fibre through the space created. If it works great - if it doesn't you're without an internet service until things get sorted.
There is a certain leeway as to where the ONT is sited - it doesn't have to be at the Master Socket location. Of more importance is the router is connected by an ethernet cable so can go where ever you're willing to run said cable if power is a problem.
I assume you know the upgrade to Full Fibre costs you your phone line.
Always happy to hear how things go.
krusty
The ont only needs about 4w.
krusty
I'm sorry that you have faced delays. It is though not a pee take! If the dig team is booked up then you will have wait. I do appreciate the frustration.
Terranova667
Fixes: 8
@krusty hi, if the dig team was booked up I would understand, but they have been in my street for the past week and still are laying ducting for other properties that have ordered FTTP, to me it would make common sense to do it all at the same time, but this is Openreach.
krusty
It does depend i guess on who is doing the booking of jobs (obviously most are automated) and colating them together.I've seen a small area that has ducts have repeated roadworks.  A very valid yet frustrating point made by you.
Champnet
Fixes: 21
@tf12  Power supply. You could consider a small UPS box which would  require  one  power socket and provide two or more power outlets.
krusty
idealy ups both the ont and router which would only need between 20 to 35w max
