Change Openreach engineer appointment
martinbaker3685
Hi
I have an appointment booked for an Open reach engineer to come to my property on 18th January 2022 to install full fibre, broadband. However, I have now realised I cannot get that day off work and my partner is also working so I need to change it. Can this be done online or do I need to call? Thanks
8 REPLIES 8
Fixes: 392
Re: Change Openreach engineer appointment
@martinbaker3685 I would suggest calling in - support staff cover on here is very thin.
MatthewWheeler
Fixes: 503
Hi @martinbaker3685
I'm really sorry for how long it's taken to get back to you. We've been quite busy recently so it's taking longer than we'd like to reply.
We can look at changing the date but with the recent Openreach challenges you'd be looking at the beginning of February most likely
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
martinbaker3685
@MatthewWheeler Yes please if you could change the date that would be great
MatthewWheeler
Fixes: 503
Thanks for confirming @martinbaker3685
If you can drop me a PM with the new date you'd like I can get that sorted for you
Fixes: 254
Send a Personal Message
Support staff might ask for private information to be sent via a Personal Message (PM) which new users might not know how to do. Further to that, new users might not have sufficient ranking (Just Browsing, Interested and Newbie) to send PMs:-
  • Have made 5 or more posts
  • Have logged in (and out) at least twice and made 3 posts
Having attained the (Hooked) ranking a PM is sent as follows:-
  1. Click on the staff member's name in the left panel
  2. Click on SEND PRIVATE MESSAGE on the right
Note that PMs sent to one staff member are visible to all staff members to provide support continuity across working rosters.
martinbaker3685
Thanks, it's a bit annoying you need to have 5 posts to send a direct message 🙄
Fixes: 1,666
The good news is that it’s actually only 3 posts, and also Matt manually gifted you the private message permission at the time so you can PM him. Smiley
Fixes: 254
@Gandalf
Thank you for the PM updating me on the evolving criteria. I’ll update my template.
I would have hoped that after facilitating access to PMs … Matt might have sent one to solicit the required information … ? Huh
