Can I remove the old wiring?
- My Order
- Re: Can I remove the old wiring?
12-08-2023 9:49 PM
Hello,
Just signed up for full fibre, with engineer coming to install in a few weeks.
Got old wiring in the house, several ethernet boxes around the place. Can I take these out, are they no longer necessary, like upstairs for instance? House will be decorated by time engineer comes, dont want the old boxes there if I dont need them (video showed them putting new box on inside and outside of house) so are these old ones not needed?![]()
13-08-2023 7:52 AM
Are you sure they are ethernet boxes , or are they telephone sockets ? (if youre not sure post a photo)
Telephone sockets will not be of any use anymore, but ethernet sockets could still be useful.
13-08-2023 4:12 PM
Thanks for the quick response, heres all the wiring (I know some of them are TV but just in case) Thank you!
13-08-2023 4:25 PM - edited 13-08-2023 4:28 PM
If you are definitely having Full Fibre installed, then
I, 2 & 5 are telephone sockets and can be removed.
4 is a combined dsl/telephone socket and can be removed
6 is a TV aerial socket and probably should be left
Not sure what 3 is its just a wire
Again not sure what 7 is , its a wire
None are ethernet
13-08-2023 4:41 PM
Thats amazing thank you so much for your help!
- My Order
