Broadband upgrade
eagleman
Broadband upgrade
I have recently upgraded from Standard broadband to fibre and was given the 3rd May as the up upgrade date, so for the switch to fibre has not happened still only below 4mb/s speed. How long will the transfer take, when is it likely to happen.
Regards
G.
3 REPLIES 3
Fixes: 577
Re: Broadband upgrade
Check for any tickets on your account as indicated in this thread https://community.plus.net/t5/My-Order/Upgrade-to-Unlimited-Fibre-on-2nd-May-never-happened/m-p/1919...
adamwalker
Fixes: 223
Hi @eagleman I've just checked over your account and can see your upgrade is set to go ahead on 12/5/23
 Adam Walker
eagleman
Thank you for this update.
G.
