Broadband activation
jikuthomas
Hi, the Openreach engineers connected fibre to my house and plugged in the router. It showed blue for a minute or two during which time the engineer showed me the net speed. However, it turned orange a minute or two later. He said it should resume in a couple of hours but it’s been 10hours now and no change. Really needed the internet to work over the weekend, so could use some help
12 REPLIES 12
jikuthomas
Re: Broadband activation
The username is my name on the admin page.
Fixes: 386
@jikuthomas Is this FTTC - via a telephone master socket, or Full Fibre - via an ONT?
Fixes: 479
Moderator's note:
Thread moved from Broadband to My Order
jikuthomas
I don’t have a telephone nor a telephone socket. So I guess it must be the ONT?
jikuthomas
Please see my avatar as I wasn’t sure how I could post the image in the chat. Apologies
Fixes: 386
Like this?
jikuthomas
Yes that’s the one.
Fixes: 386
Yep, like that. 😉
Try removing the cable fron the back of your Hub, wait about 30 seconds, and then reinstall it.
jikuthomas
Tried that, didn’t help. Still orange
Fixes: 386
OK - one last idea before I retire for the night. On the right-hand side of the ONT is a pinhole - press a paper-clip or similar into that until the lights change, wait until they go  solid green and see if your Hub connects.
If it doesn't, all you can do is call Plusnet in the morning a report a fault.
jikuthomas
Eureka!! I had reset twice before this and it didn’t work. Glad I tried a third time after your advice. Thanks for your help.
Fixes: 386
I love a result! 😀
