Broadband Delay
JJP1999
Broadband Delay
I originally had ordered internet and set the activation date as the 19th October, however my moving in date had been pushed back therefore I needed to change the activation date. This was seemingly a quick and easy process and after a quick phone call I had verbal and written confirmation that my new activation date would be the 3rd November.
Fast forward a couple weeks and I have now moved into my home and turns out the broadband wasn’t working. I ring on the 4th November to ask why and after about 25 minutes of them testing things it turns out that somehow my order had been cancelled and that they would have to restart my order meaning it could take up to 10 days for my broadband to work.
After a bit of back and forth the advisor tells me she will see what she can do and will ring me back on Monday 6th November. This phone call was simply to tell me she had ‘tried everything she could’ however my activation date would have to be the 17th November, THIRTEEN days after the original, correct activation date.
The advisor claims there is nothing they can do and they’re waiting on openreach to do their bit, they couldn’t give me a phone number and said that i will just have to wait. I’m not sure how there isn’t some priority service I could be given seeing as this is their error and I now have to wait 2 weeks for broadband with very poor phone signal in the meantime.
Does anyone know if there’s another contact I can make to try and push this forward? Baffled as to how I’m expected to wait another full cycle for their error.
3 REPLIES 3
Fixes: 387
Re: Broadband Delay
@JJP1999 If the service at your new property was ceased, as seems to be the case, then it has to follow OpenReach's rules, and I suspect the new activation date is due to engineer availability, as connecting you involves some actual physical work at your fibre cabinet.  You, as an end user, have no contract with OR, which is why they can't give you a contact number, and Plusnet have to work to OR's schedules.
Mav
Fixes: 518
Re: Broadband Delay
Moderator's note(s):
Thread moved from Broadband to My Order.
Forum Moderator and Customer
MatthewWheeler
Fixes: 503
Re: Broadband Delay
Hi @JJP1999
I'm really sorry to hear about this.
I can see you've raised a complaint online and one of our High Level Escalations team will be in touch soon
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
