Another Hub 2 query
madka
Another Hub 2 query
Like others ordered full fibre 25th July.  Date for installation confirmed as 2nd August.
Ordered new router and paid for the postage.
I see from others that they only post this out a day or 2 before installation but I haven't had any confirmation of my router order and I hate uncertainty!
No updates appear on my account either.
Can anyone tell me if my router is in the pipeline please.
13 REPLIES 13
Fixes: 388
Re: Another Hub 2 query
What does your order tracker say? (a screenshot would be useful).
willcutforth
Fixes: 113
@madka I can safely say it has been ordered so we are just waiting on it being delivered for you Smiley
 Will Cutforth
Fixes: 388
@willcutforth Does this mean the OP has had notification?
madka
Thank you @willcutforth
@jab1  no order tracking shows on my account at all and no notification so far.
Silly but this uncertainty about whether it's going to arrive on time I find quite stressful
Fixes: 388
@madka I find that a little strange, although I appreciate the vagaries of the PN system do throw up 'funnies'. However, if @willcutforth  says it is on its way, I would tend to believe him.
What router are you currently using?
Fixes: 118
@madka
If you currently have a Hub1 I believe it can be used for FTTP. You simply plug the ethernet cable into the red WAN port.
Fixes: 480
@jab1
To be fair, Will said that it was ordered, not shipped. My guess would be that it will be shipped today.
Fixes: 388
Good point, @Baldrick1  - I thought today was the 31st Embarrassed, which would have made it very tight.
madka
Finally got a confirmation text to say its ordered and will arrive in a few days.
Hope they post asap!
Thanks to all for your replies.
Fixes: 388
IF it is ordered today, it will ship today or tomorrow by RM Tracked24.
Fixes: 480
@madka
They are sent out using the Post Office tracked 24 hour service.
willcutforth
Fixes: 113
Yeah so you are right @Baldrick1 it was ordered today so it should be shipped today which you will see it within the next day or 2. It was actually ordered without my interference just coincidental that it happened today when you asked @madka
 Will Cutforth
madka
Hub arrived today.
Thanks @willcutforth
