Activation date much longer than quoted
Matb1ack
I placed an order today and selected an activation date of next Tuesday. However I received a confirmation stating a date two weeks away.
This is a new flat with a brand new Openreach FTTP box installed, everything is connected, no provider has previously provided service on the box so it's not a switch over.
I'm wondering why I'm waiting two weeks for a self install when all that is required is to send out the router for me to plug in. If I'd have known it would take this long I'd have chosen a different provider.
Can anyone explain?
40 REPLIES 40
Fixes: 353
Re: Activation date much longer than quoted
@Matb1ack I would guess that this is due to BT engineer availability.  Despite the fact that the infrastructure is installed, there are 'behind the scenes' operations which still have to be performed.
Fixes: 554
As part of the ordering process , the system will attempt to test the ONT to check it is functional. It sounds like that test failed and so now an Openreach engineer appointment is required to complete any installation
@Matb1ack  is the ONT powered and what LED's are on ?
Fixes: 353
Forgot that Embarrassed
Matb1ack
Thank you for replying
Power is green and PON is flashing green, these are the only lights lit.
Fixes: 353
Is your Hub connected to the ONT?
Matb1ack
I don't have a hub yet, my understanding is they send it out closer to the activation date.
This order was only made yesterday and I was delighted when the system offered me an activation date of next Tuesday.
Then I got emails saying 2nd of May
Fixes: 554
I'm not totally sure but I think that means the ONT isnt correctly configured
Given that, the ONT would have been installed during the build, it sounds like this wasn't completed properly. Its possible that the Openreach engineer recorded an incorrect ONT serial no against the property.
Either way, it does sound like the installation can't go ahead as a remote activation, it needs an Openreach engineer and that's why the date has been pushed back. I'm afraid that will apply to any ISP who tries to order FTTP.
You might try calling Plusnet to check what the situation is, mention the ONT PON flashing and they MAY be able to do some more detailed checks including checking if the ONT has the correct serial number.
Fixes: 353
Ah, OK that makes sense. It appears, from a quick Google that your Fibre circuit is set up - the flashing PON - but maybe Plusnet are a bit behind.
Might be an idea to give them a call and see what the hold-up is.
Fixes: 554
@jab1 there seems to be conficting information out there as to what a 'flashing PON' actually means.
I was going by this https://community.bt.com/t5/BT-Fibre-broadband/FTTP-PON-light-is-flashing-on-my-ONT-modem-what-is-wr...
Fixes: 353
@MisterW I was going by this: https://www.zen.co.uk/help-support/ont-diagnostics/  as they seem well versed (although it appears to be quite an old article).
Fixes: 554
@jab1  yes but does
Flashing green if it's making a connection
mean it has a connection OR its trying to make a connection . I suspect its the latter, and it can't make one because the ONT serial no isnt registered.
Fixes: 353
Think you may be suspecting correctly - but who knows? 😉
Matb1ack
Thank you
I suspect the developers have put the hardware in but haven't informed Openreach they need to do the splice.
I'm the first occupant of a renovation which has been made into flats. It would make sense they need to get an engineer out to finish the job 🙄
Frustrating, the fibre boxes were in weeks ago, if they had told Openreach promptly it wouldn't be an issue.
I'm not calling as solved quite yet but it seems logical
Fixes: 554
@Matb1ack the fibre must have been spliced , otherwise the LOS led would be on and the PON light would be OFF.
My guess (and its just a guess) is that everything is installed and spliced BUT the ONT's have been registered incorrectly to the various flats.
Does the BT wholesale address checker https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome show different addresses for each flat , and does each have their own (correct) UPRN ?
You can check the UPRN here https://www.findmyaddress.co.uk/
