Upgrading from 500 to 900 FTTP
loweandbehold
I’m 12 months into a 24 months contract. I’ve been offered to upgrade from 500 to 900 for an extra £5 a month. I’ve read conflicting messages online where some say it’ll require a new contract, whereas some say my current contract will continue as normal.
Does anyone have a definite answer?
Many thanks.
7 REPLIES 7
Fixes: 558
Re: Upgrading from 500 to 900 FTTP
@loweandbehold whilst I don't know the exact terms of the offer, its usual that any upgrade involves starting a new contract.
Also, be aware that Wifi speeds will still be limited to around  450Mb unless you have a Wifi 6(or 7) capable router and client.
Note that the Plusnet Hub 2 is not Wifi 6 capable.
loweandbehold
@MisterW
Hi, many thanks for the quick response Smiley
I always thought it’d only trigger a new contract if you were changing service mid-contract, such as fibre to full fibre. But if it’s only a change in speed, I don’t see how that’d warrant a new contract as it’s the same service. I’ve reached out to Plusnet but thought I’d try my luck here in the mean time.
Thank you for the advice also. I run it through Deco XE75’s throughout the house that are 6E. It’s mostly for my PS5, phone and MacBook that are all Wi-Fi 6.
Fixes: 558
@loweandbehold
Only Plusnet can definitely confirm or not whether a re-contract is part of the offer, so I'm afraid you need to wait for a staff response.
Happy that you seem to have the Wifi speeds covered though.
beeceegee
Fixes: 5
When I upgraded from 500 to 900 (for a few ££ LESS than I was paying for 500!) it kicked off a new contract
Fixes: 558
@beeceegee that's what I would expect.
@loweandbehold
Even though its only a change of speed, it still involves an order from Plusnet to Openreach for the new product. That in turn involves a commitment (by Plusnet) to Openreach's minimum term for that for that product and thus a corresponding commitment from the customer.
loweandbehold
Ah, damn. Many thanks for confirming. I think I’ll leave it then, don’t want to trigger another twelve months.
Thanks everyone for your advice, much appreciated Smiley
Fixes: 105
@loweandbehold
The other question is - do you actually need the extra speed? Sounds good on paper but would it make any difference to your daily activities.
