Static Ip won’t enable
TH90
I’ve tried but the static IP won’t enable, I’ve tried several times.
4 REPLIES 4
Fixes: 387
Re: Static Ip won’t enable
Welcome to the forums, @TH90 - have you paid the one-off £5 charge, and if you have, have you rebooted the Hub?
Fixes: 585
@TH90 the online automated static IP mechanism is broken for many accounts. A staff member will be along shortly to manually enable it.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Account / Billing
MatthewWheeler
Fixes: 503
Hi @TH90
I've sorted that out for you now.
If you reboot your router you'll get it assigned
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
