Static IP no longer available?
norliss
My full fibre service was activated earlier so I thought it I'd log in and buy a static IP address but the option was no longer there. I called up and was told this was no longer available. If this is the case it seems to have been dropped very suddenly and with no notice? Can anyone confirm if this is correct?
195 REPLIES 195
poweredbyveg
Static IP
Any chance I can get a static IP address?
Regards
Paul
Tags (1)
Re: Static IP
@poweredbyveg
Have you tried logging in to your Plusnet Member Centre, ordering a static IP address and paying the fee, (one off £5, I think)?
Fixes: 117
Re: Static IP
@poweredbyveg
There's some question at the moment if you can actually order a Static IP through your Members page. When I checked a few days ago the option wasn't shown.
I would suggest phoning PN and asking for it. Even if available online it still needs a staff member to activate it.
poweredbyveg
Re: Static IP
Yeah that option isn’t on my account. Will phone them up. Cheers.
Fixes: 1,495
Re: Static IP
Moderators Note
This topic has been moved from Broadband to My Account / Billing
salxyz
Set-up Static IP
Hello. I've just called PN to enquire about getting a static IP address. Initially I was doing a bit of research and saw your could buy one for £5 from the add on section of your account, but this no longer seems to be the case.
PN told me over the phone that static IP addresses are no longer being issued - Is anyone able to confirm if this is true?
Thanks.
Tags (1)
Fixes: 479
Re: Set-up Static IP
That is not my understanding. Try ringing again.
norliss
I just rang up and was told the same. Either the CS people are misinformed or this option has been dropped very suddenly....
Fixes: 581
I've escalated this to management since like @Baldrick1 , I'm not aware of any removal of static IPs
Markuk
Be good to know what’s happening and what it means for those of us who currently have a static IP
Fixes: 249
Re: Static IP no longer available?
@norliss
There has been no announcement of the removal of static IP address availability.  Certainly some users have reported that the ability to add (or in my case remove) static IP address has disappeared from the user portal.
There is some possibility that the agent you spoke with got this wrong - you could try phoning again.  In the meantime, another SU has escalated this query for clarification.
Markuk
Did you get a response yet about the static IP’s? I’ve sent a DM on twitter and not heard back either
Fixes: 581
There wont be much staff presence over the w/e so I don't expect much response till Monday...
Markuk
The IP Address FAQ page has also been taken down, redirects to the broadband FAQ
https://www.plus.net/help/broadband/understanding-your-ip-address/
