Static IP Address
kwhelpton
Static IP Address
Hi There,
I've previously paid for a static IP address on my account, as far as I understand I should still be receiving this? I appear to be on a sticky ip at best.
Many thanks,
5 REPLIES 5
Fixes: 1,495
Re: Static IP Address
Moderators Note
This topic has been moved from Broadband to My Account / Billing
Marsh
Fixes: 42
Hey @kwhelpton,
I’ve resolved the situation for you. Please reboot your router, and the static IP should be applied.
Josh
kwhelpton
Hey Josh,
Many thanks for that. That appears to be working now. I asked previously for the Rdns of this to be set to whelpton.uk as well, is there any chance you can reset that as well for the new ip?
Many thanks,
Windings
Fixes: 14
@kwhelpton  I've sent you an email and put a ticket on your account regarding your request. Can i kindly ask that you update your 'A' record to point towards your new static IP, otherwise our netops team wont be able to complete the task I've raised.
Cheers.
Joe Elliott
kwhelpton
Great stuff thanks. I've updated the domain records.
