Static IP Address & Ping Question on FTTP
goldenfibre
Seasoned Pro
Fixes: 12
Plusnet has upgraded my parents from SOGEA 80/20 to Full Fibre 160/30 successfully. But, I was surprised the static ip address remain the same on FTTP as it was before on SOGEA. I thought if you change to FTTP as part of upgraded from SOGEA, you will lose Static IP Address?
Full Fibre speed test with 11ms ping: https://www.speedtest.net/result/a/11496090678
I thought Full Fibre are very low ping? Why it still on 11ms as it was the same as before on SOGEA.
2 REPLIES 2
Fixes: 147
Re: Static IP Address & Ping Question on FTTP
@goldenfibre
The static IP Address is accountname based NOT connection.
Was the speedtest from a wired device?
Maybe consider setting up a thinkbroadband BQM
RealAleMadrid
Fixes: 68
@goldenfibre  Static IP address is linked to the user account so a change to FTTP  does not change the address
